So I want to create a big field of wheat using V-Ray proxy and MASH to distribute them. Does anyone know if level of detail (LOD) meshes work so I can less dense meshes show up farther away and more dense meshes show up closer to the camera?
So far I’ve tried importing two LOD meshes, converting each one to a V-Ray proxy and then attaching them to MASH but no luck.
Basically I’m trying to find a way to render faster a lot of V-Ray proxies and thought using an LOD system might help.
Create MASH system with the high proxy at the front with a visibility node to have a fall off towards the back.
Duplicate that MASH network and replace with low proxy and invert the fall off so they appear at the back.
Here you could have a blend by using the offset -1 scale with falloff object.
Red being high res and blue being low, though it is camera specific, no good for a fly over.
