Uv change grass material to vertical
Hi, does anybody knows how to change the uv to make the grass material vertical, i had searching for a lot information and i did’t find a good clue. very thanks for anybody who give me a hand…greetings
Welcome to our forum - just to make sure, you probably refer to having grass horizontally, coming out of a wall for example? If so, please let me know, we have a feature request filed for this on our agenda. If you refer to something else please let me know as well. :slight_smile:
Hey Demian, yes i want to render a vertical vegetable wall for a restaurant
but the vegetative materials are very flat
and when i put 3d models, the file come very heavy
Thanks for your wellcome and for your apreciable tips dude
I see now @Eduardo_Huerta ! So, grass on walls so that it’s horizontal or simply appearing as wall mounted is not yet possible - so you’d have to refer to using vegetation from our Asset Library for example instead of grass, and I can also see that you were able to achieve some nice results on the very far already of the scene? :slight_smile: Still, I’ll also forward your request to have grass coming from walls as well in the future.
Yes i had tried to putplants from the library, but it take to much Ram memory, anyway very thanks for your help.
What may also help a bit is placing them down, then saving only the potplants (the collection itself) part as a separate .skp file, which you can then re-insert again as a linked model (via our “Enscape Objects”). This will at least reduce the performance cost from SketchUp’s side. :slight_smile:
