UV Projection mapping through Spline
You don’t need to re-create splines in max. In PS select what you want and created Work Path. Then, File/Export/Paths to Illustrator and export as Ai file. In max import your ai path, which will come in as a spline. Density of spline points is controlled by PS path. Hope this helps. Zoran
