i have a surface and i want to map different materials onto this surface with the help of splines (z-projected). i don´t want to make black/white maps to project material.
so i want a material only to show up in the inner or outer area of the spline.
woul´d be cool if it works just like multiscatter with borderspline/borderbehaviour…
distancetex is worth a try.
we have quite big terrain with the wish of quite good detail if you´re near. (about 5000 m x 5000 m) we have plane splines that define the special parts of materials on terrain.
thing is to render B/W maps for blending (maybe in smaller quadrants to rise the amount of detail of transition between the different materials…) or to have faster solution for the problem )
