V-Ray 2.0 for 3ds Max Compatible with 3ds Max 2015
I am currently using V-ray 2.0 with 3ds max 2013. Just want to check whether is v-ray 2.0 compatible with the latest 3ds Max 2015?
Yes, you can download the latest version 2.50.01 from our web site. It supports Max 2015 64bit.
Hi Tashko,
Thank you so much for your clarification. Version 2.50.01 is available for free download as long as i have purchased 2.0? Do i need to change the dongle?
Changes to the dongle are not required if you have V-Ray 2 licenses. Just make sure that you will get the 2.50.01 (advanced) version and not the 2.50.L30 , which works with V-Ray 3 license.
You have to login with your username and pass (chaosgroup.com) in order to be able to download the installation file.
If you have any problems with that, please contact us via our support ticket : support at chaosgroup.com
Hi Tashko,
Thanks a lot for the information. I will try to install that after purchasing Max 2015. =)
