V-Ray 5.20.01 spinner sensitivity
After updating to V-Ray 5.2 the spinner sensitivity in the material edit increments only by 0.1 and is very sensitive. When dragging the cursor up only a tiny bit dials the spinner up to 1 and downwards it instantly goes to 0.
Is there a place I can fix this? I tried using the 3DsMax spinner settings but that doesn’t help.
Running 3DsMAx 2022.2
Hold ALT while using the spinners.
Using ALT helps, but still it adjusts only 2 digits after the decimal. the third digit stays ‘0’. Normally using ALT you can fine-tune the spinner at the third level.
Hi, looks like a flag has to be set explicitly for the spinner controls to autoscale. We’ll fix this. Thanks for the info.
Alexander
