V-Ray 5 cosmos material
Since July 29, 2026, I (my client) have been unable to access Cosmos materials in V-Ray 5, receiving the error “No assets found in your plan”.
3D Models and HDRI are working fine.
Please check this.
I’ll ask the devs about this.
EDIT: FYI, tried with V-Ray 7 on 3ds Max 2023 and it works fine. Will forward the devs say.
Thanks for confirming.
I think the cause is V-Ray 5.
The devs responded that they are on it.
Thank you for your assistance. We will wait for the fix.
The issue has been fixed in the latest Chaos Cosmos update (Build: 2026.08.05-700679). Try it out.
Thank you for the notification. I have confirmed that the issue has been resolved in Build: 2026.08.05-700679.
Thank you for your support.
Hi , I’m having the same issue. Materials are not available in my VRay 5. Only the Fabric materials are available but for all other categories of materials I get “No assets found in your plan”.
I use V-Ray for SketchUp online licensing and I’m not sure hat plan I’m supposed to have. I have installed the fix Build: 2026.08.05-700679. but it hasn’t resolved the issue. Can you help please?
Thanks, Babeta
This seems like a separate issue. I suggest you open a ticket - the technical support team can further assist from there.
