V-Ray 5 for C4D didn't work since updating to macOS 10.14.6 Mojave
Hello, since updating my iMacPro yesterday to macOS 10.14.6 Mojave, V-Ray isn’t running anymore. I can set it up in the render settings but the material icon doesn’t show up and when you try to edit the material. nothing happens. Before that, it worked perfectly. Any suggestions?
My configuration is: iMacPro (2017) with macOS 10.14.6, Cinema4D R 20, V-Ray 5 for Cinema 4D (v5.00.42 from Dec 10 2020). Thank you for your help! Volker
Hello @TeamStiefelhagen ,
Are you using the latest version of Cinema4D? If not, please update it and try again. If that doesn’t work, please try reinstalling V-Ray and let me know if that helps.
Hi Aleksandar,
do you mean the latest release (R23) or the latest version of my version R20? I tried to reinstall with the R20 Version but this doesn’t work. Thank you for your help!
Best regards
Volker
Hi Aleksandar,
if C4D R23 is needed, I got this version, too. But it’s on another machine and I have to transfer my 3.0 license to the other machine (without properly knowing how to do that).
It’s a bit frustrating that I can’t test VRAY 5 properly. BTW: I strongly believe that VRAY 5 is an awesome product and I can imagine how much work it was to build the “5” version for C4D for the Mac between new macOS versions and the new Chipset.
My license runs out on Jan. 13 - will it be possible to use the trial version in order to check if it works correctly?
Thank you in advance for your help, Volker
Could you please create a ticket via our contact form here describing the issue? Please mention this thread in the message.
Hi Aleksandar,
thank you, I just opened up the ticket!
Best regards
Volker
