Hi everyone,
Since the last V-ray update 1, I’ve had a very annoying bug when using my GPU (Cuda or RTX) to render my visuals on Sketchup. This however doesn’t happen when using my CPU.
Alongside this message are two screenshots illustrating my issue. You can clearly see in the screenshot using the GPU that the background has a very weird effect as if a vanishing point was added. This greatly distorts the image making it unusable.
When using the same backgrounds without update 1, I don’t have this issue which tells me this probably isn’t an issue with my settings. This also happens for all my projects.
Whenever I need to render a background in an image, I need to use my CPU which takes 10 times as long… I can sadly not downgrade to an earlier V-ray version as I need some of the new assets.
If you have any idea of what could cause this, I would be more than thankful.
