V-Ray 7 for Cinema 4D, Hotfix 2 is now available
Hello everyone,
V-Ray 7 for Cinema 4D, hotfix 2 is out.
The builds can be downloaded from the Downloads section on our site.
Here is the change log for release version 7.00.02
Modified features:
  • Add an option to select a material type (Node or Classic) when importing from Chaos Cosmos
  • Make Cosmos Variants import / load faster
  • Utilize the Cosmos error reporting notifications
  • Improve lights’ shadow bias range and default value
  • Improve render startup with Scatter in interactive
  • Allow rendering when unsupported Redshift nodes are present in the scene
  • Change VRayProxy Alembic subdivisions layout​
Bug fixes:
  • Velocity artifacts with the GeomScatter plugin
  • Slow export of Scatter with VRayProxy or Cosmos objects
  • Crash with GeomScatter prior version when “Null” object is present in the scene
  • V-Ray might crash when trying to render without a license
  • Linked materials are not deleted when variant is changed while cosmos asset with Classic materials is imported
  • Classic material previews can turn black
  • Crash with VFB Layers
  • V-Ray prevents command line process from exiting
  • Wrong export of object hierarchies nested under a Chaos Scatter object
  • Infinite Light Cache building in Interactive Rendering with MoGraph Selection on Cloner Object
  • Crash when using solo mode on outlines node
  • Chaos Scatter crashes on Windows with interactive rendering
  • Specific scene crashes when submitted to Chaos Cloud
  • Importing displacement with subdivisions from a V-Ray scene file doesn’t work
  • Disable V-Ray Frame Buffer regions affecting the viewport interactive rendering
  • Cinema 4D Crashes when changing UVW Projection Node to Camera Mapping
  • Unable to update Cosmos materials after calling the Cosmos relink command
  • V-Ray PRG Sun mode is not visible in Light Lister
  • Fix Chaos Cosmos proxy import to work with the Edge Trimming option of Chaos Scater
  • Floating I/O nodes do not work
  • V-Ray Frame Buffer may crash when mouse cursor is changed on hover controls
  • Chaos Scatter may not update automatically with V-Ray 7
  • Light Material with a Bitmap is not editable when importing a V-Ray Scene file from 3ds Max
  • Wrong labels for some parameters using special terminology
  • V-Ray: Named hair map channels are not rendered
  • V-Ray VFB has high enforced minimum size when scaled Cinema 4D layout is used
  • Incorrect result with animated Bend Deformers
  • V-Ray GPU: Changing assigned materials in interactive doesn’t affect the render the first time when V-Ray Object Properties tag is assigned
  • V-Ray GPU: “Hardware textures” mode is not exposed in the user interface
  • V-Ray GPU: Cinema 4D crashes when rendering viewport previews with AMD GPUs
  • VRayProxy: Merging V-Ray specific files makes other materials in the scene darker in Cinema 4D 2025​
