V-Ray 7 for SketchUp, update 1 is now available!
This is a technical release that includes necessary backend changes, but it also brings a few new features and improvements you might find useful.
It can be downloaded here:
download.chaos.com
Regards,
Konstantin​​​​​
Improvements & Bug Fixes
  • Chaos Scans (VRscan materials) can now be loaded and rendered correctly without a Scans license
  • The entire Chaos Scans material library is now available in Cosmos
  • A new distributed rendering mode called Classic DR is implemented. Use it as an alternative to Swarm by manually configuring the network environment
  • Chaos Account management window is implemented
  • The handling of all license errors is improved
  • An issue preventing the standalone V-Ray denoiser from working is resolved
  • An issue with stopping a GPU render in a project where Caustics are enabled is resolved
  • The V-Ray installer now requires a CPU with AVX2 instruction set support to run
  • An issue causing Cosmos assets to render black when the global Material Override is configured in a particular way is resolved
  • Material Override’s Split Refractive and Preserve Properties features now work with Enscape assets
  • An issue with the silent installation of V-Ray for SketchUp, when using a config file, is resolved
  • An issue with the update of Cosmos assets’ variants during interactive rendering is resolved
  • A number of issues with the Vantage live link are resolved
  • A number of issues related to the Material Override feature are resolved
  • An issue with the import of V-Ray Scenes containing Proxy Scene references is resolved
  • An issue causing the removal of Proxy Scenes containing only other proxies when their Preview Face Count is set to 1 is resolved
  • An issue where the Chaos Sign In webpage would incorrectly open during V-Ray activation in certain cases is resolved
  • An issue causing error when opening the Asset Editor for the first time while a live Vantage session or interactive rendering is running is resolved
  • An issue preventing the Asset Preview rendering in specific situations is resolved
