V-ray and nodes update questions
Hello. I bought 1 license of V-ray 7 perpetual. I bought 3 V-ray render node perpetual licenses. I have PC1 and PC2 running 3ds Max 2022 (I am only 1 person so I only GUI use 1 at a time). I also have PC3 that is render node only, no GUI max or GUI V-ray.
During heavy render I want two or all three of them DR together.
What do I do different installing the latest V-ray 7 on those 3 PCs given the above usage? Any different install settings? PC1 and PC2 can trade back and forth being GUI used by me or nodes. PC3 doesn’t even have activated Max installed so it is Render node only - never GUI.
Also, PC1 also has GUI 3ds Max2020 installed in addition to Max2022 because I also have Phoenix 4 perpetual and it will not work with Vray7 or on max 2022. So uniquely for PC1, I want to have V-ray 5 installed into 3ds Max 2020, and V-ray 7 installed into Max 2022. I read on here that is possible. I am about to embark on doing all this and need guidance please. Thank you.
Lastly I have an OLD PC with GUI 3ds Max 2016, 2017, 2020 and V-ray 4. It has plugins the others do not have so sometimes I need to use it for projects and if heavy render is needed I can bake the project and then move it over to the newer more powerful PCs to finish the project. Will V-ray 4 still work on this OLD PC or will it trigger a problem on the Chaos server when it launches? I will not try to DR this old machine with the newer ones.
Reminder, only 1 PC will be GUI used by me at a time. PC1 and PC2 could be GUI or nodes, PC3 is node only. OLD PC is standalone for project starter or certain legacy standalone projects.
A sincere thanks. I’ve been wanting to get all this going for years and life problems have gotten in my way
There’s a docs page about the installation process here.
In short:
  1. You install the “Workstation” type on your workstation and the 3ds Max Render node type on the render nodes.
  2. You install a Local License Server on the main machine and set the render node machines to use it. A local license server is needed for Distributed Rendering (via VRaySpawner).
Otherwise, no problems with having different 3ds Max versions with different V-Ray versions. However, for a job to work with distributed/network rendering, all machines must have identical 3ds Max and V-Ray versions (for CPU DR). For GPU DR, you only need identical V-Ray versions. So I suggest you reserve a 3ds Max 2022 for this, since you can install the latest V-Ray 7 updates on it.
The old pc should work fine with the legacy V-Ray builds.
Thank you.
For the PC3 that is render node only, I see these different V-ray 7 install options:
  • workstation
  • 3ds max render server
  • standalone render server
for PC1 and PC2 that will trade back and forth as workstation/render node the installation asks if I want to update to cloud licensing “v-ray has detected a chaos license server on this computer.” I’m pretty sure I want to “user license server”
So to keep things more simple, when max render speed is needed I’ll Distributed render linking all 3 PCs, I’ll use V-ray7 and 3ds Max 2022.
For old projects I’ll just use:
3ds max 2016, V-ray 4. PC1 or OLD PC by their self.
3ds max 2020, V-ray 5, PC1 by itself
