V-ray clipper causing dead pixels in refraction...
I’m using a vray clipper to clip off some refractive elements in an ST pass.
I’m getting some black spots though.
You can see right where the elements get cut off, but then there are those black spots. I’ve excluded everything else from the clipper except for that one object.
I’ve turned material refraction Max depth to 100 and global Max. transparency levels to 1000. No change.
Any ideas?
Thanks!
Sorry, this seems to be solved by checking “Use Object Material”
Thanks!
