V-Ray denoiser plugin for Nuke WIP
Thank you Vlado and Chaos Team
Wish that could be done for Natron too.
But I don’t think that’s going to happen.
When is the release date ? :slight_smile:
Natron has potential but its missing a lot to get anything like this to be implemented in there. the dev team is foucesd on Locking down the 2d engine and stabilising the code. it would be a long way till they introduce alternative rendering method to get even the denosier in there.
Could this ever make it in a After effects plugin? :slight_smile:
Fusion is wish.
It is free.
Our developers’ time is not free though :slight_smile: Let’s see how things go with the Nuke version first.
Hello Vlado,
would it already be possibly to receive a version?
even if the plugin is still in the beta stage.
Kind regards
Alex
I do not see this posted currently on http://help.chaosgroup.com/vray/misc/
When will this be made available? Looks fantastic.
There’s a bit more work to be done before it’s ready for public eyes…
Hello Vlado,
we are currently testing the denoiser in vray 3.4.
I made some test with Lele’s script and it work like a charm !
Now I’m trying to work with the nuke plug in, more easy to work with.
It’s working directly in Nuke 10.0v4 in “workstation mode”, but it always do a runtime error when used in “render mode”.
It happen on the same machine.
We are using Deadline 8 to send our job.
Job report :
Error: RuntimeError: Cancelled
at Deadline.Plugins.PluginWrapper.RenderTasks(String taskId, Int32 startFrame, Int32 endFrame, String& outMessage, AbortLevel& abortLevel)
2017-01-18 08:06:37: 0: STDOUT: K:/Vacheron/VCH035_GrandeSonnerie/7_3D_render/_Anim/P2060/MVT/DIFF03
2017-01-18 08:06:37: 0: STDOUT: >>> [ 8:06.37] Warning: VRayDenoiser1: Knob:chan_rgb. Setting knob values from validate is not supported and may cause unexpected behaviour.
2017-01-18 08:06:37: 0: STDOUT: [ 8:06.37] Warning: VRayDenoiser1: Knob:chan_alpha. Setting knob values from validate is not supported and may cause unexpected behaviour.
2017-01-18 08:06:37: 0: STDOUT: [ 8:06.37] Warning: VRayDenoiser1: Knob:chan_noise_level. Setting knob values from validate is not supported and may cause unexpected behaviour.
2017-01-18 08:06:37: 0: STDOUT: [ 8:06.37] Warning: VRayDenoiser1: Knob:chan_defocus. Setting knob values from validate is not supported and may cause unexpected behaviour.
2017-01-18 08:06:37: 0: STDOUT: [ 8:06.37] Warning: VRayDenoiser1: Knob:chan_world_positions. Setting knob values from validate is not supported and may cause unexpected behaviour.
2017-01-18 08:06:37: 0: STDOUT: [ 8:06.37] Warning: VRayDenoiser1: Knob:chan_world_normals. Setting knob values from validate is not supported and may cause unexpected behaviour.
2017-01-18 08:06:37: 0: STDOUT: [ 8:06.37] Warning: VRayDenoiser1: Knob:chan_diffuse_filter. Setting knob values from validate is not supported and may cause unexpected behaviour.
2017-01-18 08:06:37: 0: STDOUT: [ 8:06.37] Warning: VRayDenoiser1: Knob:chan_reflection_filter. Setting knob values from validate is not supported and may cause unexpected behaviour.
2017-01-18 08:06:37: 0: STDOUT: [ 8:06.37] Warning: VRayDenoiser1: Knob:chan_refraction_filter. Setting knob values from validate is not supported and may cause unexpected behaviour.
2017-01-18 08:06:37: 0: STDOUT: [ 8:06.37] Warning: VRayDenoiser1: Knob:chan_atmosphere. Setting knob values from validate is not supported and may cause unexpected behaviour.
2017-01-18 08:06:37: 0: STDOUT: [ 8:06.37] Warning: VRayDenoiser1: Knob:chan_background. Setting knob values from validate is not supported and may cause unexpected behaviour.
2017-01-18 08:06:37: 0: STDOUT: [ 8:06.37] Warning: VRayDenoiser1: Knob:chan_global_illumination. Setting knob values from validate is not supported and may cause unexpected behaviour.
2017-01-18 08:06:37: 0: STDOUT: [ 8:06.37] Warning: VRayDenoiser1: Knob:chan_Lighting. Setting knob values from validate is not supported and may cause unexpected behaviour.
2017-01-18 08:06:37: 0: STDOUT: [ 8:06.37] Warning: VRayDenoiser1: Knob:chan_reflection. Setting knob values from validate is not supported and may cause unexpected behaviour.
2017-01-18 08:06:37: 0: STDOUT: [ 8:06.37] Warning: VRayDenoiser1: Knob:chan_refraction. Setting knob values from validate is not supported and may cause unexpected behaviour.
2017-01-18 08:06:37: 0: STDOUT: [ 8:06.37] Warning: VRayDenoiser1: Knob:chan_specular. Setting knob values from validate is not supported and may cause unexpected behaviour.
2017-01-18 08:06:37: 0: STDOUT: Writing K:/Vacheron/VCH035_GrandeSonnerie/7_3D_render/_Anim/P2060/MVT/DIFF03//DIFF03_Denoise_1301.exr Reading Input Frame: 1300.00
2017-01-18 08:06:37: 0: STDOUT: debug: Setting up 48 thread(s)
2017-01-18 08:06:37: 0: STDOUT: Reading Input Frame: 1300.00… 66.9 %
2017-01-18 08:06:38: 0: STDOUT: debug: Threads completed
2017-01-18 08:06:38: 0: STDOUT: Reading Input Frame: 1300.00… done
2017-01-18 08:06:38: 0: STDOUT: Reading Input: 0.748000s
2017-01-18 08:06:38: 0: STDOUT: Reading Input Frame: 1301.00
2017-01-18 08:06:38: 0: STDOUT: debug: Setting up 48 thread(s)
2017-01-18 08:06:38: 0: STDOUT: [ 8:06.38] Warning: Read1: get(channels=0x7ff8000f), but request() not called.
2017-01-18 08:06:38: 0: STDOUT: Reading Input Frame: 1301.00… done
2017-01-18 08:06:39: 0: STDOUT: Writing K:/Vacheron/VCH035_GrandeSonnerie/7_3D_render/_Anim/P2060/MVT/DIFF03//DIFF03_Denoise_1301.exr took 2.01 seconds
2017-01-18 08:06:39: 0: STDOUT: Total render time: 2.01 seconds
2017-01-18 08:06:39: 0: STDOUT: Traceback (most recent call last):
2017-01-18 08:06:39: 0: STDOUT: File “stdin”, line 1, in <module>
2017-01-18 08:06:39: 0: STDOUT: RuntimeError: Cancelled
2017-01-18 08:06:39: 0: Done executing plugin command of type ‘Render Task’
Any clue ?
Best regards.
Can you tell me which version of the denoiser plugin you are using? Or the date of the DLL?
hey.
from my perspective it look like a channel bug of some sort.
hace you tried testing alterntive renders on the box to see if the same bug happens? or is it only that render and that frame on that box?
dose it happen locally?
dose the box have a good GPU?
The free version doesnt support plugins, so if there was the vray denoiser available you’d have to start paying for fusion.
@stilgarna
I managed to reproduce the problem and it seems to happen when frame_blend is set (not 0) and rendering without GUI.
We’ll see to cleaning up the warnings and fixing the issue.
Could you confirm if your setup works when frame_blend is 0?
Thanks!
wait… is the Vray denoiser plugin for Nuke available now? Link please.
Exactly like that.
Expect also in the OpenFX version.
It can also be used in Fusion Studio and Natron.
It is here.
http://forums.chaosgroup.com/showthread.php?91595-Any-news-when-denoise-elements-will-be-available&p=720722#post720722
November 9 2016
Yes it works with frame_blend set to 0 !!! :slight_smile:
Thanks !
This denoiser is just… no word… game changer ! I hope I can post some test scene soon
In CPU mode : 3min20s - 4min00 (i7 970)
In GPU mode : 1min30s (very old GTX 470)
Crazy !
Very good job guys !!!
The denoiser apparently uses a custom render element called “noise level.”
Looking at a multi-channel EXR in Nuke, I do not see this render element.
I do see the all others (world normals, etc) and the Nuke denoiser appears to be working fine.
I was just curious as to why I was not able to see the “noise level” render element in the EXR.
