I am using V-Ray for Rhino to render my project. Does anyone know how to adjust the background color. I follow the YouTube tutorial, but it does not work. Thank you.
You find the controls at the Environment option.
Please show a screenshot of your environment options. If you use background only than this is used for all functionality. If you like to free control the background, than assign the sky to GI/refl/refrac environment (best as instance per drag&drop) and now you can set any background you want without the scene is affected.
Right, you need to change your setup like it can be seen at my screenshot. Drag&Drop the blue map symbol to the other slots (enable the slot before, like at my screenshot).
Great, thank you.
Hi ziyao_zhang,
The V-Ray environment settings work in the following way:
I hope that this information helps you (and that it makes sense).
Regards,
Konstantin
Hi Konstantin
Thank you for your explanation.
Ziyao Zhang
