Hi guys,
I’ve published this post in the public channel, but this should be the proper venue.
I’m new in this forum. I’ve bought a license of V-Ray for Maya and tried to make a sphere with a particle system emitted from its surface.
I’ve associated a VRay Metaball to the particle system and on Viewport 2.0 I can see the particles on the surface (img1 below).
However, when I render (img2 below), the particle system (and the Metaball) are not there.
Can you help me understand how to render correctlya and what’s wrong here?
Everything in the setup looks correct to me in the V-Ray Metaball attributes. One thing that you may check is the render status of the particle system. It should be “Renderable” in order to get the metaballs rendered.
If that’s not the cease then please attach your file here or send it to support@chaosgroup.com to see what is wrong.
Thanks Tashko,
I don’t know hot to verify that the render status of the particle system is “Renderable”. Can you check me from the attached file and let me know what’s wrong?
Thanks.
Currently we don’t support V-Ray Metaballs in CUDA/GPU renderings and this is the reason way you don’t see them rendered. If you switch to CPU engine everything should work fine.
