Thanks for your reply. This is a problem across the entire creative software industry. In the early 2000s all of the experienced technical writers got laid off. In some cases (Autodesk), new people were hired who would work for less. In other cases (Adobe, apparently) the tactic was to solely rely on user forums to do the work for free.
So the statement “documentation is big and difficult” doesn’t really address the issue. The underlying problem is the lack of respect for qualified tech writers. The underlying assumption is that teachers and writers are worthless, that developers can easily do those jobs in their spare time. But I am here to tell you that developers are the very dead last people who should be trusted with user-facing documentation. It takes a special talent, developed over years and decades, to translate technical language into something that is useful to users.
This is a prime example of what I am talking about. Developers, project managers, anyone directly involved with the creation of complex software, has enough on their mind. It is not their job to explain things. You need people who have devoted their careers to explaining things.
There is absolutely zero benefit in “describing what each of the models looks like”. That is a complete waste of time and is utterly misunderstanding the entire purpose of documentation. If you have posted renderings of what the various models look like, there is no point in attempting to describe those images. We can see the images for ourselves. If you want to comment or call out specific visual phenomena that are not blindingly obvious, then, great. But describing an image is only useful for the visually impaired, which is not your audience.
What WOULD be helpful is defining what those various models ARE. You don’t need to go into excessive detail, but if you’re going to bother using up screen space, tell us something we don’t know.
Bump maps and normal maps simulate fine surface detail without altering mesh geometry. Rendered pixels on surfaces, known as shading points, are pushed in different directions relative to the surface. This is a lighting effect that doesn’t change the mesh shape, and so the silhouettes of objects are not affected.
The word “normal” has multiple meanings in 3D.
A surface normal is a line or vector extending perpendicular to each polygon face.
A vertex normal is a line or vector extending from each point on the mesh. At each polygon vertex, there’s a vertex normal for each connected face. So at a point where four polygons connect, there are four vertex normals. Vertex normals can be oriented in any direction to determine the hardness or softness of edges, and how the surface responds to light.
A bump map or normal map is an image or pattern that simulates the lighting effect of a mesh vertex normal at every shading point, giving the illusion of surface relief.
Bump map: monochromatic, single-channel height map that deviates shading points in the direction of the polygon surface normals. The brightness or intensity of the map determines the amount of relief, with brighter colors corresponding to greater deviation from the surface.
Normal map: RGB map in which shading points are deviated in three directions, instead of only one direction as with a bump map. The intensity of each RGB color primary encodes the amount of surface deviation in a single direction in XYZ space.
Normal map in tangent space: The frame of reference for each pixel in a tangent-space normal map is the polygon surface normal. The XYZ axis tripod of each pixel in the normal map is positioned and oriented at a tangent to the corresponding polygon face.
Normal map in object space: All pixels in an object-space normal map share the same point of reference for XYZ shading deviation: the pivot point of the object.
Normal map in screen space: The frame of reference for each pixel in a screen-space normal map is the position in the picture plane of the rendered camera. The XYZ axis tripod of each pixel in the normal map is positioned at the corresponding X and Y coordinates of the picture plane, and oriented with the camera.
Normal map in world space: All pixels in a world-space normal map share the same point of reference for XYZ shading deviation: the world origin.
