V-Ray Object/Light Properties
Was dealing with some particles (pflow) today and noticed that the only way to make them hold-outs (I think) is to apply an override material to them - which is cool - but not nearly as easy as being able to access vray properties of specific events… Which got me thinking, could the V-Ray object/light properties be located under the standard max properties dialog, under their own tab?
Not sure, maybe that’s dumb.
Just an idea :slight_smile:
If you could access the standard max properties for each event, you would be able to change their user attributes, no? (the V-Ray properties are user string attributes).
I suppose? The standard max properties can be set per-event by right-clicking on the event in pflow. I don’t know if that differs from setting object properties outside of pflow…
