V-Ray Setup no saved at Rhino 8
the setting for s-RGB slider, advanced materials and custom material library are not saved and available after reopen a Rhino file at a new Rhino task.
-Micha
Hello, Micha,
Was not able to reproduce the behavior you described.
Can you please specify the exact version of Rhino WIP and V-Ray you use?
Do you switch between V-Ray and Rhino default render engine at some point?
I just tested it again and it works here too. Maybe my Rhino has a temporary problem or the last update fixed the problem.
Thank you,
Micha
