V-Ray should reflect Max color management setting
V-Ray does not reflect mode change in default Max color management and stick always to OCIO evironment variable if is present. This should not be hardcoded and there should be some way how to prevent this, maybe some other envar like <always_use_ocio> false/true or something like that.
Hi Can you share some examples and also which version of V-Ray you are using. Thanks
Linking the other thread for clarity.
V-Ray 7.4 and Max 27.2. As mentioned in the link posted by hermit this behaviour is intended and in don’t think its the right choise :slight_smile: there should be a way to turn it off.
