Has anyone else had a render, using V-Ray’s sun & sky, get darker the closer you bring the camera to an object? I cannot get a close look at the elements in my scene because the closer I move the camera, the dimmer the lighting becomes.
Hi, thanks for posting. Check your scene carefully, there must be something in it that is causing this. Could you record a video of the issue? If you’d like send your scene over here for review. You can also use the support contact form but please add a link to this thread in your message to support.
