V-Ray wizzard - request for contribution
This could cause a lot of problems, much like hiding and unhiding objects or doing polygon reduction on objects that fall outside a cameras field of view. Seeing as an object will have an effect on the light bouncing around a scene, it’ll make a difference to the overall solution of the space you’re in so you might get weird light solutions if you need to rotate back to look at an area, there might be a hard edged shadow from an object whos samples may have only been taken from a certain view but since it’s already appeared in shot by your logic, it mightnt get sampled again for a different view - I reckon you’re still better doing this by hand, you might be able to more accurately guess where you need your samples than vray since you know exactly the details that you need to bring out.
Perhaps I wasn’t clear enough.
The intent is not to cull objects from the scene, only to optimize the “every nth” rendering of imaps in an animation. For instance, as it stands the basic workflow is to render imaps every 50th frame or every 20th frame etc., this is rather ineficient as perhaps frames 1-120 might be a zoom in 120+ moving into a pan, where the calc for the first frame would suffice for frames 1 -120 you would need more frequent calc’s for the pan.
The method I see working would be shooting a rough grid of rays from which one could ascertain whether they are hitting new geometry or not.
make sense?
Sure yeah - What I meant was it would have to take into account objects that leave the frame and come back in so there aren’t any holes left in the sampling - it’d have to almost do a pre pass for each object and find out when its visible in frame and not - it’d be almost like making a bsp tree for the animation - You may end up with inaccuracies if you dont shoot enough rays. I reckon this might still be more sensibly done by the person that made the animation in the first place. You could quite happily use the render dialog to specify the frames you want to render (1,3,100,150,160,300 or whatever) rather than having to go through a fairly large pre process to get correct results since vray doenst know in the grand scheme of things what frames actually matter in the end or not.
I’m not convinced that it would not work :slight_smile:
The grid would not need to be that dense that it would take long to sample, maybe one ray per 10 pixels or so and could also be set to sample every nth frame. Each ray would return what object it intersects. Then the values for each frame could be looked at for overlap.
That an object leaves the view and comes back is usually not an issue since it will already be considered in a previous imap. Of course it will fall apart on some crazy camera moves but for 90% it should work.
Since we are looking at automation and convenience I do not think it is too far fetched.
I agree with Tricky. I too have spent a great deal of time and effort learning the program, and still am, by the way. The “magic button” idea is not one I agree with. And if you think something like that won’t cost you work, your very, very wrong. The very best quality is not what everyone in the architecture business is looking for. And if your clients know there is a “magic button” for descent quality renderings, your overall value to them will drop as well as more people start using vray, and they will. Which is obviously what chaos wants, I would if I were them.
Competition is a very real thing, and mastering your programs is what gives you the advantage, because you were willing to invest the time and hard work. I freelance, so this may effect freelancers more than established firms.
And to compare vray with Maxwell is obserd. Maxwell is finished as a viable product. Just read their own forum. And they had the so called “magic button”. Of course, thats all they really had.:slight_smile:
Just my 2 cents worth and there is every chance I could be wrong.:slight_smile:
Tony
This stuff about losing business is the same as a few years back, when traditional lighting artists complained about GI renders. Any dick tom and harry would be able to create photoreal images without placing fill lights at every wall and under every table.
A wizard is a good thin imo, especially for learning from it. But nothing beats the actual knowledge of the software. So not just anyone will be able to steal your job. What will they say to to a client who wants a change, but they can’t do it because they can only use the wizard and there is no ‘make my walls brighter’ or ‘decrease the color bounce only on this wall’ checkbox?
In a few years time, all you know now will also be obsolete because then CPU’s will be good enough to render every still with ppt, which only needs one setting to control quality. But by then, a lot of other stuff will be implemented to make images even more real which requires even more cpu power, raising the standards for photoreal again. Have you ever thought about the fact that 99% of all vray settings are only there to fake and to speed up things? Take the speed issue away and you will never have to tweak ir map tresholds and glossy subdivs etc…
So bring on the wizard, and bring on the new load of artists who will finally be able to use vray without a degree in physics and math!
I am not quite sure what to think about the wizard idea. Some clients appreciate shite so what do you do with them? They also can’t think outta the box so they are clueless how to use good 3D images. For example one potential client I have uses absolute crap images to sell their developments and they actually think the images their architect produces are good. They have a show room with all these horrible 3D images everywhere . . . ugh! The shite comment was confirmed by a third party potential client I talked to who made a harsher comment about the other potential clients showroom.
I guess my fear would be the same as Tricky and TRGraphics as if this architect got a hold of a wizard his output would take a big, big leap forward not because of his skills in producing the image but because he bought Vray and can use a wizard.
At the same time I have confidence in myself that I would be able to compete against wizard weilding, non-knowledgable, psuedo 3D artists as, like Tricky and TRGrphics, I have invested a great deal of time learning and still am learning Vray. These other people will not have spent that time with Vray and there in lies the competative advantage. I know, at least to some degree, what I am doing whereas these aforementioned people won’t. Anyway I guess I am a fence sitter. :?
Well, of course knowing what the settings do is always an advantage… It is like programming in assembly language - people can do it for small portions of the code where optimization is critical, and for the other parts of the code they leave the optimization to the compiler, which may not do the best job ever, but for the invested human effort (e.g. none :-)) it performs very well. Having a good optimizing compiler doesn’t make you a good programmer though - it just takes a large technical burden off of your shoulders.
I should note that such a wizard is not at all easy to create as there are many many factors that must be considered, so it won’t come in a week or two for sure. For now, it is just an idea…
I’m a frequent lurker and infrequent poster, but this topic is very interesting to me.
Personally, I think the idea for a V-Ray wizard is a very good one and I’ve been hoping for something of the sort.
The argument that it will hurt professional profitability strikes me as a little absurd. (No offense intended to those who hold this opinion.)
My productivity would be improved by any features that allow me “dial in” good render settings more quickly and consistently. I am much more an artist than a scientist. I want to focus my skills on the subject/modeling, composition, lighting and mood (among other, more subjective considerations), not render theory and multiple test renders. To me, getting a job done well and quickly will always help my bottom line.
I spent the first decade of my professional career doing all of my work on a drafting table with technical pens, markers, gouache, airbrush, etc. I still remember quite clearly the attitudes of my colleagues when computer software began taking over their various fields of arch viz, graphic design and illustration. Many were certain that with the advances in software and hardware that any idiot could do their work and we’d all be competing for scraps. Of course, that didn’t happen. Oh sure, we all had to redefine how we competed in the marketplace and how to leverage the new tools to our advantage, but what else is new? If a potential client is satisfied with renders that were created without a fine eye for detail, accuracy and good composition, then they were going to undervalue my efforts anyway.
I for one, hope that this idea is pursued further.
Thanks!
I think that no doubt this would make the competition greater. On one hand it’s frustrating to think of loosing skill. We have taken the time and learned a skill set. Some one then says “Hey you no longer need to know that. You can just push these buttons”. Pretty common in this computer world though. Trhuthfully I have my own wizard. Well I do the exact same things everytime to set up a scene. Sometimes I copy directly from a simular file. I don’t tweak as much as I used to and I want to tweak less. If Chaos does not give me a wizard I will just refine my own.
Seems that something we all like about this is it’s hard to do. We know stuff and it’s not easy and we charge because we know stuff. I am better than a cad drafter because I have taught myself how to use these programs and I get better results. Now to many of use there is this real fear that soon the programs will be “easy”. That cad drafter doesn’t need to know that much and he is getting pretty picts. 5 years from now will Acad have v-ray and all you need to do is press the radio button that says int or ext and in 30 seconds it’s rendered? These are my fears. They are not keeping me up at night mostly because few architectural firms I know care that much. Most could be using BIM but are in 2d and the thought of a full time 3d guy is not a reality as most places are understaffed. They really “could” do what I do but they don’t and not because archi firms don’t have creative people but because they can’t afford the man hours off a set of drawings.
Anyway I rant.
I think we all know that this type of high level pre-programming is coming. It will eventually be in everything we use to make a living in this business. I just want it to be after I retire! :slight_smile: I turn fifty next month so vlado, give it a few more years for us old guys. hehe
Call me old fashioned, but I believe you should have to work hard to get ahead in any business, including this one. I am fortunate in that I love what I do for a living and I want to protect that from pencil jocks as long as I can. I guess I’m selfish that way.
I’ve been around long enough to have seen the first space capsule go into space live on my folks 20" black and white tv. I’ve seen technology grow by leaps and bounds that no one could possibly have predicted. The day we’ve been discussing is coming and I don’t really fear it, I just want it to waite a few more years.
I also believe that talent is very important in what we do and you can’t program that into a button. But, there are a lot of firms that believe “good enough” is just that, good enough. I deal with it often in trying to get new clients. The easier software is to use out of the box, the lower the value is of the person using it. That’s just a fact.
I don’t have a boss that just drops work on my desk and says do this. I have to hustle for my work, just as a lot of people here do. And that’s my choice. I prefer to work for myself. The more advantages I have, the better for me. And when it gets right down to it, that’s who I’m concerned about in this business, me.
Oh well, enough of my bullshit.
Tony
The bottom line of 3d viz is that you want to produce nice images. So the talent lies in color choices, lighting setup, material creation and composition. These are things the wizard will never do for you. So many talented people who don’t use vray now because they get scared of all the speed optimizations, will finally be able to use vray. I don’t think you need to be talented to set all the parameters that the wizard will do for you, you simply need training.
I agree with Tricky and TRGraphics. This is the same thing as with this vray materials program. At first it is nice idea but soon we all will get from our clients something like “comon you want to much for this project I know the guy who do it in few clicks so why you charge so much.” and he will go to this cheapier guy whu got this one click button software. But I guess this is how this world works everyone want easy, fast and cheap way of doing money.
Up until the mid 1800’s, oil painters had to make their own paints by grinding and mixing dry pigment powders with linseed oil.
I suspect a large number of talented, established oil painters of that time found the increasing availability of premixed paints in tubes to be offensive to their careers and to devalue their skills.
The impressionist painters had no such biases and readily adopted the new paint tubes. :wink:
It was the same with the web industry when the entire thing went down. Everyone was saying that they were a web designer with some people charging thousands, others charging a few hundred so as you mentioned, people started asking “why are we paying all this money when the other guy can do this far cheaper?”. The clients buying peoples services weren’t smart enough as regards 3d to see the difference between good work and bad work so the good companies lost a lot of their small work to people making sites from their bedrooms with frontpage or ms word. You either have to educate your clients about the difference between good work and bad work or alternatively try and get clients who are sophisticated enough to know the difference already.
As myself and flipside mentioned, the major difference will be artistic choices rather than settings so you should be able to win out on that.
Good points raised here. My thoughts are swaying. It is definately ‘the way the world works’ and you can’t really stop that. Client education is key also - many of our clients don’t know what makes a good image from a bad one, and this is our main worry. We often don’t get a chance to educate them as much of the work is done without ever meeting our clients. We will just need to adapt. Again!
Business is never easy.
In my opinion you get repeat work because a client likes you and your professional attitude to your work - you do the best you can and your experience counts
I’m the same age as TRG… progress is unstoppable
I really don’t think a wizard will be a magic button - it may get you 80% of the way there more quickly - so it raises the bar - that’s good all round
Despite Vlado’s skill at programming, I don’t think it will be a magic button too, but something more along the lines of the presets in the IMap Options. It’ll be a great help for setting something up quickly but as we all know we quickly depart from these presets depending on the scene and what we are trying to do (testing materials, lighting, animations, small image vs. large image, etc.) I believe there are really too many variables to get a top quality image that can’t be programed (i.e. texture quality, lighting setup, materials, modeling). If the wizard helps me get my renders done quicker, I’m all for it. That it helps everyone else as well I don’t really care.
I guess what I’m saying is that I just think the bar will be raised across the board. Years ago clients were happy with just a wireframe drawing of the 3D model, then a shaded view, then a raytraced view, then a GI render. What’s next is up to us.
Its all about the work you do…the end product…how you get to it should be unimportant or at least transparent to the client. I can’t see how having a tool that would allow you to be more efficient and effective could hurt the ability to compete…that’s just me though. Its a good idea Vlado. Anything that can take some of the grunt work out of setting up scenes is a good thing. My hope would be that this could be an educational tool as well. It would be nice to go through the wizard for different scenarios and see where the settings changed and be able to output a settings breakdown for comparison sake. My problem all along, and i think some might agree, is understanding all the settings and how they relate to each other.
Looking forward to this…again…its a good idea Vlado. Keep up the good work.
I really don’t get it. Can’t you see you’re already using a lot of easy software yourself, where 10 years ago you needed a programmer to make it work? I mean just take your OS and how programs work today! I really can’t believe these complaints. If you think that speeding up the scene setup time will get you to loose clients, I think you’re handling your job wrong. Even with the simplest and best combo of settings, this doesn’t garantee a good image! BTW, if we would have faster pc’s today, this whole wizard thing wouldn’t even be necessary, because you could just use ppt and render every high res still in 10 minutes. So maybe complain about CPU speed increases too, because there will be a day that a todays render will only take a minute, and oh no, you spent so many time setting up a render farm and now all this knowledge isn’t necessary anymore. There are way more other treats to your job than a vray wizard!
Do you ever use the ir map presets?? I don’t, because I can always set it up better. But it did help me understand the software. Same for the wizard, it won’t help us but it will help new users.
