when renderin fro vrsnce in vantage I have an opacity bitmap sequnce that works but when the opacity goes to fully black or fully white I experiance a jump in the image, is it fixeble are there any workaounds?
Hi kostia_naimark,
Do you have Stochastic opacity set in the Render settings tab? (https://drive.google.com/file/d/1upZPNzKrEm8trIPIm3Z8MVhqRKqdaqMC/view?usp=sharing)
If no, then I would suggest you enable it and try if it fixes the issue. If it is set to stochastic can you send us the scene to investigate? You can use the Chaos Help form with a link to the forum thread: https://support.chaos.com/hc/en-us/requests/new You will have to include all asset files.
​Best regards,
Alexander
