After using assets from the enscape (not custom assets) like people, grass, and street lamps that have worked fine for over a year, random selections of these assets have come to be thousands of meters tall. I have to go through the document and find the name of the enscape asset and erase it which takes a long time. When I re-insert the same enscape asset, it still comes in at a huge height. Still, others are just fine.
omegle xender
Do you know the reason for this?
Thank you.
It remind me of this problem:
16836-enscape-assets-scaling-problem
The issue was resolved with an update. So not sure if it would help. But it’s something.
@HasarangaWanindu , as already correctly linked and stated above, this should’ve been resolved a while ago.
Still, if you could please try the following:
"delete the folder %temp%\Enscape\Assets and restart Enscape. All assets should show up in their intended scale.
You can also find the folder via this path: C:\Users%username%\AppData\Local\Temp\Enscape\Assets"
If that doesn’t do the trick, then please instead send us a Feedback report with log files as described here too. Then we can have a look at those to troubleshoot this further.
