I have a very small experience with .vdb file.
With PhoenixFD I have created a simple exploadion (with the preset tool), inport the .vdb file in Corona and try to play.
As you can see:
() there is a problem with the shadow
() I’m not able to create a nice “emission” shader
Here you can download the files:
— DOWNLOAD—
Where is the problem? =)
This looks like a bug I noticed (and reported internally) yesterday - if there is a light inside the CoronaVolumeGrid object (the bounding box for it, not necessarily inside the part with voxels) and if there is an object (such as a plane) also inside the CoronaVolumeGrid, then lighting seems to be incorrect.
Thank you TOm. And, what about shader? Are you able to create a nice “Explosion Emission light”? =)
Well, there’s no shader in the conventional sense, it’s all built into the CoronaVolumeGrid object. I’ve had it working fine, just need to select the correct data to use to drive the Emission, Temperature being the most likely one to use (the hotter it is, the more it glows). Then adjusting the Scale and maybe the gradient in the Grid mapping if you want to adjust the colors and how they fade off. Of course you could drive it using Density, Velocity, or any of the other parameters too, but Temperature is the one that would work best for Emission.
Hi Tom, yes, I knew this, but thank you for the explanation =) It will be useful. But, if you open my file (you will find .max file and .vdb file) I’ not able to create a “nice” result", even if I use temperature channel or other channels for the Emission. Only with Smoke_phx channel (llok at the image above) I have a nice and correct preview (point clouds viewport), but the rendering is awful
. Feel free to “play”
PS: the “Velocity” channel look like completely broken.
Ok, the problem of the shadows, tt’s not a bug.The plane and the CoronaVolumeGrid object are both exactly on 0.00. If you move the CoronaVolumeGrid object at 0.01, the “bug” is solved =)
Never tested with Phoenix FD output, just the free OpenVDB files from over on the OpenVDB site - the explosion from there worked as expected for me. Will see if I get time to take a look at the scene, but can’t promise, as the next Academy is coming up and looking into how Phoenix saves OpenVDB files could be complex
My first thought would be to check the Scale, as not sure if different applications write different high / low values for their metadata.
On the bug, yes, if the plane (or presumably any object) intersects the OpenVDB, then this happens - does sound like the one I reported internally. Have added a note there to point at this forum post as another example of it, btw!
Ok, I tried to download the explosion from
And the Temperature channel is ok.
I think something is wrong inside the PhoenixFD .vdb file… But I don’t know where it can be the problem. I’m not expert in VFX
Join the club
I did want to try creating something from Phoenix, as I wanted to test an animated OpenVDB and I can’t find an example anywhere online (if anyone knows of one, let me know!) - but I have no idea how Phoenix FD exports to OpenVDB nor the details of what export settings there are, and how that changes how we import it - all new territory since the functionality has never existed for us before haha!
If anyone knows more about exporting to OpenVDB from various applications (should be possible from Blender and Houdini too for example), feel free to share info, knowledge and experiences! And to test CoronaVolumeGrid of course!
Ohh.. with PhonexiFD is very simple:
() Select a teapot and use PhoenixFD toolbar by pressing the “Explosion Sim” button. PhoenixFd will do everything for us.
() Select the Grid and, in the rollout “Grid” decrease the resolution (to speed-up the test).
() In the rollout “Output” select the directory and the .vdb format"
() In the Simulation rollout, click… “Simulate”.
(*) If you prefer to see the point clouds, in the “Preview” rollout, press “GPU Preview”.
That’s all =)
Ok,
here we can download a very simple and fast (low res) .vdb sequence of explosion created with PhoenixFD with default settings.
Try to obtain a nice rendering with CoronaVolumeGrid, if you can ^_^.
— DOWNLOAD —
So did some testing on a sim from Phoenix FD here, and it is indeed the scaling of the Temperature. Not sure if there’s a way to adjust it on export from Phoenix, but on import I had to use very small values in the Emission Scale, and in the Input Scaling (I ran Auto-scale first too), and fairly dark colors, and very low positions on the grid - see attached image.
Since it works in a much more “expected” way with the sample OpenVDB files, and can be made to work by adjusting the settings for a Phoenix FD exported OpenVDB, I am thinking this is related to how Phoenix is writing out the temperature rather than a bug or issue with CoronaVolumeGrid.
PS - without that 0 level point in the Grid at above the halfway mark that keeps everything at the zero until quite far along the scale, the non-flame parts of the CoronaVolumeGrid will also emit light and ruin the effect - so again seems to be how the Temperature is being scaled from the Phoenix FD export.
Thank you so much Tom. Maybe it’s a bug in the way how Corona reads Phoenix temperature’s value. I don’t think it’s Phoenix problem =)
I’ll ask the devs and find out one way or the other
As for the missing shadow in the first image of this thread, this is an old Corona issue, which is related to all volumes (not only OpenVDB). This will be difficult to fix, unfortunately. For now, just make sure that objects don’t intersect the volume grid bounding box (they either lie completely outside or completely inside the volume).
As for the PhoenixFD temperature, it is for some reason stored as very high numbers compared to temperature exported from other software (FumeFx or Blender etc..)
The only thing I can do about this is set the input scaling automatically when I somehow detect that the OpenVDB file was created by PhoenixFD.
Hi martinsik,
thank you for the explanation. I think that you should find a solution for a better compatibility with PhoenixFD.
Not it’s very difficult to create some good Emission shader with the Temperature channel.
Maybe you can ask help to Chaosgroup
Have you tried my .vdb sequence? Even with very low Scale value, it’s impossible to obtain what I had directly with PhoenixFD.
Speaking with Martin:
“We will be redoing the UI of CoronaVolumeGrid and we will also address the issue with the temperature”.
Great support, as usual.
Looks like the Emission from Phoenix FD should be fixed in the latest daily (it was related to how Phoenix does black body radiation by the look of the comment in the changelog):
“emission data can now be optionally interpreted as temperature (calculating black body radiation color) + associated temperature scaling - this is automatically detected for Phoenix FD files and for others containing “temperature” channel”
