Veras 3D model to create AEC Walls from a bitmap on a plan
Status: declined
Could you implement in Veras, as you did for Sketchup and Revit, the creation of AEC Walls objects by reading an architect’s GA plan (jpg on a A1 plan, as we are doing to trace walls, put doors and windows)?
Adding the door objects and windows object if we provide Veras an elevation plan as well.
I have enhanced the Door object by adding elements to it and they are still working properly with the AEC Walls ( creating the automated boolean operation to cut hole in the wall). It would be great if we could tell Veras to look in a specific folder for our modified Door Objects, to place them at the right place in the AEC Wall object.
thanks
Hi, currently, the Standalone version of Veras is not provided for V-Ray for 3ds Max. Nevertheless, you could try an MCP server installed on your DCC software (3ds Max), which should manipulate and create objects in your 3ds Max file. This is not directly related to the work of V-Ray in 3ds Max. Nevertheless, with the same MCP you will be able to control V-Ray processes as well.
