After few days from the first installation of Corona 1.4 I suddenly noticed a great performance decrease when rendering the material previews using the slate material editor, but even with compact editor. It’s incredible… sometimes it seems to work and after few minutes no more.
I have a FairSaas license… is that possible due to lags of internet connection???
I noticed an other strange thing… at the day of installation of 1.4 the default image filter was “Parabolic” and now it opens by dafault with “Tent”.
Are you getting freezes within the material editor? Is it freezing for a few seconds/minutes? If so, you could try the following solution:
Uninstall Corona using the uninstaller which is bundled with Corona (you can select it on the page of the installer where you select various items).
Then:
Go to your 3ds Max installation directory
Make sure there is nothing (file or folder) with the name “Corona” inside. You can use Windows search function for this (Ctrl+F). If there is anything - remove it.
Go to C:\Users_username_\AppData\Local\ and remove CoronaRenderer folder
Go to C:\Users_username_\AppData\Local\Autodesk\3dsMax\2016 - 64bit\ENU (or any other version of 3ds Max or language) and remove anything which has “Corona” in its name
Install Corona 1.4 again
I have the same problem. Even changing the color of the material takes several seconds and freezes max.
I did the procedure you describe, but is always the same.
I wonder if this isn’t the issue that was once persistent on quite random occasion some long time ago. I’ll dig in my memory to see what all I tried, because I did eventually get rid of it (after a lot of desperation).
My Solution: I just had to install eeevvvery single windows update available, may be it was something related to DotNet version, or C++ version. But finally it worked!
Thanks!
I’m having the same problem, the material editor is really slow, mainly the first time I open it.
Maru’s suggestion didn’t work for me either. I love version 1.4, so I hope there is a solution…Corona 1.3 doesn’t have this problem.
Update: I uninstalled and reinstalled EVERY visual C++ package in my system and now the problem is solved.
Spoke too soon…
To all having problems with 1.4 and material editor:
It may seem strange, but some problems (especially crashes) are related to licensing. I would suggest removing all files from
C:\Users_username_\AppData\Local\CoronaRenderer
…and then re-activating the license.
Other problems may appear if some other type of materials is set as defaut in meditor (e.g. vray materials).
Here is how to remove the Vray/other settings and set all material editor slots to Corona materials:
in 3ds Max go to Customize > Custom UI and Defaults Switcher, then select “Max” on the left list, and “DefaultUI” on the right list. Press “Set” and restart your 3ds Max.
I’d like to add that after installing “Convenience Rollup” for Windows 7 SP1 which acts
as a SP2 and all the windows updates, material editor’s speed has definitely improved.
That’s hardly a solution, because, you know, there are people who needs both, Vray and Corona. Maybe your Vray installation had problems, what if you try to reinstall it and update to latest version? Would that solve slow material editor problem?
I tested it lag.
So. Results.
I started 3ds max. Open mateditor. ME rendered 3-5 slots. Then lag. After few minutes rendered other slots and continue. If i try swap some slot on new material(from library, coronamtl) its slot lagged again. But not longer. Few seconds.
So. What i do. At first i open task manager. When I open ME at first, my CPU loaded by 100%. Then, when all slots in ME rendered, CPU loaded normal (10-15%). When i added new material. CPU again 100%.
I cheked process. And what i see there? I see 3ds max and svhost loaded CPU. What? svhost? Rly? Why? I kill it task! And… all was well. Any lags on ME. Fast added new material. Fast slots rendering.
I try do it again. I close max. Then started in again. Max atarted. And svhost started again. I open ME. Lagged again. I close max. Start again. And at first kill svhost task. Then open ME. All OK. Any lags. So. Its svhost. If you kill it task, lags in ME go away. But only for next max starting.
I make a short video. Look please. (bdcam.exe in tasks - its bandicam, videomaker)
