Minor issue but nonetheless very annoying.
If I make an adjustment to the vertical offset of a background image in the VFB using the arrows (which adjusts 0.001 each time), then toggle the ‘As foreground’ checkbox and then try to readjust the v offset using the arrows, it jumps by 0.02 meaning I have to reset the BG image every time. Doesn’t do this if I adjust other things such as cam rotation.
Hi, thanks for posting. There is indeed some discrepancy in the slider’s response if we enable “as background”. I will check if this can be improved and get back to you.
The issue is logged under VMAX-13971 in our bug tracking system.
Any new on this one? So frustrating as I have to use this quite a lot.
Additionally, would it be possible to introduce a VFB option to change the opacity of the render? It would avoid me constantly having to check and uncheck ‘As foreground’ when aligning.
No movement yet.
There’s an opacity slider in the Background layer already.
Can’t believe I didn’t spot that! So I can have the background as foreground and use the opacity. Thanks.
Any update on VMAX-13971? It’s been a consistent frustration for years now and would love it to be resolved.
I’ll ask the product manager if we could prioritize it.
