VFB issues____Vray 6.3
Does anyone know how to restore VFB? While the VFB open it’s not displaying on my active monitors. I reinstalled Vray but still no luck.
Type this exactly into your listener, and press the keypad enter.
It matters not to the code execution whether the VFB is open or not, so try and open it again if you still don’t see it (it means it was closed.).
vfbcontrol #pos "reset"
Just needed this too. Thanks :slight_smile:
Could this be done for all windows? For some reason some of them (name detached object) or something pops up outside my 3 monitors. Quite annoying and I have to "ALT + TAB > M > random arrow key > Move mouse " to get the window to attach to my cursor so I could move it in position.
which other windows?
All floating windows (render setup, detach objects,..) some of them sometimes jump somewhere unreachable.
No, we can only take care of the VFB, not the other Max windows.
This may help you.
http://polycount.com/discussion/59862/reset-floating-window-position
Thank you Lele, I’ll look into it.
Sort of on this topic,
Is there anyway to set the vfb window position along with history and messages windows size and position? each time I start max and the vfb I have to move and size these 3 windows for my 3 monitor setup…it would be nice if I could set the windows once and (with a script or automatic) have the windows pre position and size.
Thank you Lele!
it’s a window 10 or 8 thing. When I dragged max or any open folders to the corner of the screen the VFB re-appear.
