So Im using lightmix, but then adding it to a composite. Problem is that when i re-render, the vfb reverts to lightmix mode and until i remember to change back, no extra corrections are added. Seeing as the lightmix still works in the composite mode, would it be possible to have it stay in composite mode when rerendering, or would that be problematic? Its not a biggy, just an idea as the less things i need to remember the better ![]()
you can add VRayLightSelects manually without VRayLightMix element.
