VFB Problem
I have a very heavy scene and the render its painfully slow, so i hit render and went home; at home a connect to the office pc by teamviewer and the VFB went crazy (view image below), i saw the render dialog and was still on lc calc so i let it finish asumming i could close and reopen the VFB in the morning, but now im in the office and i cant save because there are NO buttons. I can use the vrimg that VFBhistory save, but the GUI on vrimg2exr doesnt exist!(its a D.O.S gui) , I thought that through the years you (chaos) updated it. How can i solve it?, i just want a jpg from the vrimg.
can’t you just close the VFB and then in viewport right click and click on “V-Ray VFB”?
or you did that and the buttons are still gone?
Also, why dont you set the VFB to auto save the vrimg file? That way you dont have to save it afterwards
As Morne mentioned if you close VFB and open it the buttons should appear - What I usually do when this happens to me to move VFB window out of the screen then when I drag it back the icons are there.
Vrimg2EXR tool does have GUI - what Vray version are you using ?
You could use VFB in order to convert *.vrimg file to JPG - just open VFB click on the load button , browse your *.vrimg file and click Open - then click Save and choose JPG file-format.
Sorry for delay, im back on track
Still gone
A terrible bad habit by my side
That didn´t work either
vray 2.40.03, does the new ones have it?
As i stated before, there was no buttons at all
I ended up with a max restart, one more thing to add on my render check list, always leave the autosave. Thanks for reading
It has a proper GUI in V-Ray 3.0; I’m not sure if it went into the latest 2.40 update though.
