When saving high-resolution (HiRes / 8K) renders, the Beauty and LightMix images often fail to save correctly — the resulting files appear completely black.
A similar issue occurs with Bloom & Glare, which seems not to be fully calculated before the image is saved.
This behavior appears to happen mostly with large render resolutions.
Hi, could you please contact us about this at https://support.chaos.com/hc/en-us/requests/new
Please add basic information such as which exact Corona and Cinema 4D versions you are using and whether it’s Windows or Mac.
If you could archive and attach a sample scene where you can consistently reproduce this, that would be great.
