Video Editor - Keyframe at same location not working
Before Enscape 3 update, I was able to create keyframes at the same location and lengthen time. This is useful to show light change throughout the day. After Enscape 3 update, I just cannot create keyframe at the same location and lengthen each keyframe. I think it was discussed soon after Enscape 3 update, but with the latest 3.02 update, it still doesn’t work.
Theoretically you can do this by changing total duration. But if I want to keep the last frame stay longer, it’s not possible. No matter what I do, the 2nd last and last frame cannot be separated. It doesn’t matter the 2nd last keyframe is “time stamped.”
@L.S , this is a known behaviour and I’m afraid for now, I’ll bring this up again internally to see what could be adjusted.
Thank you Demian Gutberlet for acknowledging as a known issue*. What’s strange is, holding a key frame at the same camera location worked just fine before 3.0 update.
