View-port materials
All of a sudden I can’t see my materials in the viewport. I changed to opengl, directx, and nitrous, but nothing. Help!
Odd… It seems my color correction material broke. When I re-create the material things start working again.
You can try to disable/enable the “show texture in viewport” option in the map that you want to see in the viewport a few times to see if it clears any conflicts with other maps in the material that may have it enabled.
EDIT: If the problem is with more than one texture check the “Display” tab in the command panel make sure that shaded mode has “material color” selected.
I tried that, but it didn’t help. The only thing that helps is re-creating the textures.
