is it a known problem that somehow corona doenst take the visibility track into account? I have an object which visibilty is animated, basically its set to 0 most of the time and then jumps to 1 in one frame. The problem is that the object is still visibile the whole time its set to 0…
Found a similar problem which was solved unfortunatly it had something to do with SSS and transculency which i dont use (index.php?topic=21309), its a rather simple material.
Found the problem…tried a simple object with the same material and it was working so it must have been something with the animated object. It was animated using a path deform using the stretch value and while it was set to 0 the object was still visible, setting it to 0.001 fixed it and the visibility track is now working as expected.
So dont use a value of 0 if you want to animate the visibility…
Sorry for the inital post, you can delete this whole thread if you want.
