Visual C++ Redistributable 2015 vs 2017
Sometime recently SteamVR started using Visual C++ Redistributable 2017 and it installed in on my PC. After this time, it appears that this has caused problems with .exe files generated by Enscape which depend on 2015. Doing some research, unfortunately Microsoft make some poor decisions where once a PC has 2017 installed, it breaks apps that try linking in 2015 “because a newer, more up to date version is available”.
I’m wondering if Enscape will migrate to using 2017 as well, this would solve this issue. I’ll try to grab a screen shot of the error message when I can get back to the VR PC.
Here it is: https://imgur.com/a/oQQ51lj
If I un-install 2017 then it works but Steam will no longer launch SteamVR
Both VC++ 2015 and 2017 redistributable are major version 14. (140 and 141) They should be compatible. Are you experiencing the problem while installing Enscape or when trying to use the a standalone exe?
The issue is when using the standalone exe. Due to the fixed license the models are developed on one person’s PC and then we export the exe to a shared VR Workstation.
It appears that this is not the actual run-time, but the installer failing. I have opened a ticket on your behalf and we will look into it.
@lgbeno What version of Enscape are you using to create the exe standalone? We fixed a bug very similar to what you described in the 2.4.1.42 hotfix (and of course our preview version)
