Vray 1.09 problems with max 7 ?
A couple questions about VRay and Max 7
Is anyone using VRay 1.09 with Max 7 and have they had any problems with the transition and what problems have been encounted.
The notice on the installer vray 1.09 says is for max 6 and may have probs with 7. Is there a max 7 version of 1.09 or when is one expected.
When is the next commercial build of Vray looking at being distributed?
We would like to upgrade the studio and would appreciate hearing any ecperinece people have had.
We have installed the Vray version on Max 7 and expite the fact that it says that may be problems we in our studio have encountered None :slight_smile:
I’ve tried to install vray in max 7 and it doesn’t even show up at the renderer picklist, which is very odd, maybe I should try it again
If the scene was created in another Vray version then create a new scene and merge everything into it with the new Vray . That could help.
Even when you specify the 3dsmax 7, the installer will create a 3dsmax6 folder inside it.
Just move the files inside the 3dsmax6 folder to the appropriate ones, in 3dsmax 7.
