VRay 2.0 displacement problem
I have a strange problem with VRayDisplacementMod.
I put a 16bit tiff grayscale texture on a plane as a displace. It is a 127 grey texture with some white and some black spots.
And result is - from black to 127 grey elevation is maybe 0,6cm. From 127 grey to white is maybe 2,5cm. But why? It has to be linear, hasnt it?
either you should turn off input gamma, or adjust your grey value.
Yep, you are right. I changed the gamma in an image loading dialog and everything is fine, thanks.
