Vray 2.3 in Maya 2013 on Mac osx - RT not working...
Hey all,
I had hoped my first post would be something more positive but I’ve hit a major snag with RT.
I’ve done a couple of searches to see if anyone else has had this problem but I haven’t found any usable results.
I recent upgraded from vray 1.5 to vray 2.3 so I could use vray in maya 2013 and also use the RT function.
I have no problem setting of a normal render but I just can’t get RT to work.
The instructions I have found to use vrayRT are as follows: Render an IPR frame… then it should work!
But everytime I try (with different scenes and also very simple scenes) nothing happens except I get a ‘scene is empty’ warning in maya and in the maya renderview it asks me to ‘select a region to begin tuning for vray’. Nothing else happens except a unix shell pops up telling me lots info including ‘error: Failed to start network server: Failed to open listening port (48)’. Which seems to indicate I need to set up distribution rendering which doesn’t match the docs…
Could I be doing some thing wrong? Anyone see any obvious issues? Anyone seen this before?
I’ve included the logs/outputs below.
Thanks in advance!
These are the logs/outputs I get:
(I haven’t included the console window log/output because it’s too long, but can include it if needed)
maya script editor:
// Warning: No image writer specified. //
// Warning: Scene is empty. //
Bash shell (unix shell):
[2012/Sep/26|11:29:40] Reading configuration from “/Applications/Autodesk/maya2013/vray/bin//vrayconfig.xml”
[2012/Sep/26|11:29:40] ===============================================
[2012/Sep/26|11:29:40] V-Ray Standalone, version 2.20.01 for x64
[2012/Sep/26|11:29:40] Copyright (C) 2000-2010 Chaos Group Ltd. All rights reserved.
[2012/Sep/26|11:29:40] Use -credits option for additional third-party copyright notices.
[2012/Sep/26|11:29:40] Build from May 29 2012, 12:56:52
[2012/Sep/26|11:29:40] Compiled with GCC-compatible compiler, version 4.2
[2012/Sep/26|11:29:40] Operating system is Mac OS X
[2012/Sep/26|11:29:40] V-Ray core version is 2.00.01
[2012/Sep/26|11:29:40] Loading plugins from “/Applications/Autodesk/maya2013/vray/vrayplugins/libvray_*.so”
[2012/Sep/26|11:29:41] 102 plugin(s) loaded successfully
[2012/Sep/26|11:29:41] Finished loading plugins.
[2012/Sep/26|11:29:41] error: Failed to start network server: Failed to open listening port (48)
[2012/Sep/26|11:29:41] Exiting server mode.
[2012/Sep/26|11:29:41] Closing log - 1 error(s), 0 warning(s).
logout
The “Failed to start network server: Failed to open listening port (48)” error means that there is another instance of the V-Ray render server already running on the machine (perhaps registered as a service) and which messes things up. Is that true?
Doesn’t the V-Ray render server have to be running for V-Ray to work in maya?
V-RayRT always uses DR. And when you don’t have it setup in the setting, we try to start a rendering server ourselves.
And it seems that on your machine it cannot open the port for listening. Probably this is some network setup problem.
The port number is 20207.
You’ll have to check if the port is used by some other application or the firewall is blocking it somehow.
/Teodor
edit: I have not seen that Vlado has answered you already…
I checked and no that port is not used by another application and the firewall is not blocking it. I even logged the local ip of my machine as a render slave and in the logs it shows that port is being used but I got the same issues and RT still won’t work. Here is a snippet of the logs:
9/27/12 4:21:12 PM [0x0-0x4ad4ad].com.autodesk.Maya.2013[51305] V-Ray: Starting render
9/27/12 4:21:12 PM [0x0-0x4ad4ad].com.autodesk.Maya.2013[51305] [2012/Sep/27|16:21:12] V-Ray: Exporting scene to V-Ray.
9/27/12 4:21:12 PM [0x0-0x4ad4ad].com.autodesk.Maya.2013[51305] [2012/Sep/27|16:21:12] V-Ray: Parsing light links time 0h 0m 0.0s (0.0 s)
9/27/12 4:21:12 PM [0x0-0x4ad4ad].com.autodesk.Maya.2013[51305] [2012/Sep/27|16:21:12] V-Ray: Translating scene geometry for V-Ray
9/27/12 4:21:12 PM [0x0-0x4ad4ad].com.autodesk.Maya.2013[51305] [2012/Sep/27|16:21:12] V-Ray: (Estimated time remaining: 0h 0m 0.1s): 64 % completed
9/27/12 4:21:12 PM [0x0-0x4ad4ad].com.autodesk.Maya.2013[51305] [2012/Sep/27|16:21:12] V-Ray: (Estimated time remaining: 0h 0m 0.1s): 76 % completed
9/27/12 4:21:12 PM [0x0-0x4ad4ad].com.autodesk.Maya.2013[51305] [2012/Sep/27|16:21:12] V-Ray: Total time translating scene for V-Ray 0h 0m 0.4s (0.4 s)
9/27/12 4:21:12 PM [0x0-0x4ad4ad].com.autodesk.Maya.2013[51305] [2012/Sep/27|16:21:12] V-Ray: Rendering with IPR (port 20207).
9/27/12 4:21:12 PM [0x0-0x4ad4ad].com.autodesk.Maya.2013[51305] [2012/Sep/27|16:21:12] V-Ray: Updating frame at time 201.00
9/27/12 4:21:14 PM [0x0-0x4ad4ad].com.autodesk.Maya.2013[51305] [2012/Sep/27|16:21:14] V-Ray: (Estimated time remaining: 0h 0m 1.7s): 53 % completed
9/27/12 4:21:14 PM [0x0-0x4ad4ad].com.autodesk.Maya.2013[51305] [2012/Sep/27|16:21:14] V-Ray: Total time updating frame 0h 0m 2.3s (2.3 s)
9/27/12 4:21:14 PM [0x0-0x4ad4ad].com.autodesk.Maya.2013[51305] [2012/Sep/27|16:21:14] V-Ray: Render complete
9/27/12 4:21:14 PM [0x0-0x4ad4ad].com.autodesk.Maya.2013[51305] [2012/Sep/27|16:21:14] V-Ray: ========================
9/27/12 4:21:25 PM [0x0-0x4ad4ad].com.autodesk.Maya.2013[51305] [2012/Sep/27|16:21:25] V-Ray warning: No image writer specified.
9/27/12 4:21:25 PM [0x0-0x4ad4ad].com.autodesk.Maya.2013[51305] [2012/Sep/27|16:21:25] V-Ray: Preparing renderer…
9/27/12 4:21:25 PM [0x0-0x4ad4ad].com.autodesk.Maya.2013[51305] [2012/Sep/27|16:21:25] V-Ray: Preparing scene for rendering…
9/27/12 4:21:25 PM [0x0-0x4ad4ad].com.autodesk.Maya.2013[51305] [2012/Sep/27|16:21:25] V-Ray: Creating texture cache with size 0 MB
9/27/12 4:21:25 PM [0x0-0x4ad4ad].com.autodesk.Maya.2013[51305] [2012/Sep/27|16:21:25] V-Ray: Creating bitmap manager
9/27/12 4:21:25 PM [0x0-0x4ad4ad].com.autodesk.Maya.2013[51305] [2012/Sep/27|16:21:25] V-Ray: dr host: 127.0.0.1
9/27/12 4:21:25 PM [0x0-0x4ad4ad].com.autodesk.Maya.2013[51305] [2012/Sep/27|16:21:25] V-Ray: Connected to render host 127.0.0.1:20207
9/27/12 4:21:25 PM [0x0-0x4ad4ad].com.autodesk.Maya.2013[51305] [2012/Sep/27|16:21:25] V-Ray: Using 1 hosts for distributed rendering.
9/27/12 4:21:25 PM [0x0-0x4ad4ad].com.autodesk.Maya.2013[51305] [2012/Sep/27|16:21:25] V-Ray: Preparing scene for frame…
9/27/12 4:21:25 PM [0x0-0x4ad4ad].com.autodesk.Maya.2013[51305] [2012/Sep/27|16:21:25] V-Ray: Bitmap file “/snet/show/am/case0001/test_Project/sourceimages/Refmap.hdr” loaded.
9/27/12 4:21:25 PM [0x0-0x4ad4ad].com.autodesk.Maya.2013[51305] [2012/Sep/27|16:21:25] V-Ray warning: Scene is empty.
9/27/12 4:21:25 PM [0x0-0x4ad4ad].com.autodesk.Maya.2013[51305] [2012/Sep/27|16:21:25] V-Ray: Running RTEngine
What is the output of the render slave?
Can you try to render with DR in Production? Here are the steps:
1. Start the server manually
2. Create a scene, relatively heavy (add domelight for example)
3. Set the number of threads to use to 1, in Settings → Other → Max render threads.
4. Add localhost to your host list
5. Enable DR
6. Render
If this works, RT will work, too.
/Teodor
Hi Teodor,
Thanks for your help with this.
I followed your steps and yes a DR render works without a problem. But RT still doesn’t seem to work.
Here are the steps I take to render with RT
Render and IPR image
It prompts me to select a region to begin tuning for vray so I draw a selection rectangle in the maya render view
The result - nothing in the maya render view, nothing in the vray frame buffer, this feedback in the maya script editor:
setAttr “vraySettings.sys_max_threads” 8;
setAttr “vraySettings.sys_distributed_rendering_on” 1;
I tried to tackle this problem from a different angle.
This time I setup two other machines as render slaves. I got those machines to work and got RT to work once they were up and running. I still wanted to have RT working on just the main machine so I dug further.
During the process of getting the other machines setup as slaves, I tried to start the slave service twice on one of the machines by mistake and got the same error “error: Failed to start network server: Failed to open listening port (48)”.
This made me look at my machine again and I noticed that I had vrlservice and vray.exe running (for some reason I hadn’t seen this before). I killed the vray.exe and that solved the problem!
Thanks for your help.
Thank you for the update!
