I just updated Vray and it seems that when I export a mesh in a VrayProxy the size is the double from what I got with Vray 2.30.01.
I’m using 3ds Max 2013 x64.
Does anyone have the same issue?
I found this change because a scene previously working now just crash when doing the light cache. If I remove the VrayProxies then it’s fine. So I’m making some test to be sure of the issue.
As a test I tried to create a box (with turbosmooth) in a scene, do a vray mesh export et hit render but it was working.
So maybe it crashes if the mesh is too heavy or something…
Hm, I can’t reproduce this; here is what I do: open the birch .max file; right-click on the tree > export .vrmesh with auto-convert to proxies; render => all is fine. I also tried importing the proxy in a clean scene - also fine.
Can you also get me the .vrmesh file that crashes?
Other than that, I’ll try to decipher the crash dump.
The only way I got it to crash was if the “point clouds” option is enabled when the proxy is created - that’s why I asked if it is on or off (must be off).
Thanks for the file; you exported the proxy with point clouds in it. That’s what causes the crash, and that’s also why it’s twice as large.
Will fix the crash of course, but for the moment, make sure point clouds are disabled when you create the proxy (this will return the size to normal), or else set the point cloud “Level multiplier” to 0.0 in the VRayProxy parameters (this will stop it from crashing).
There is a separate issue with the “Scale” parameter; will fix that too.
