Vray 3.0 Compatible Plugins List ?
Hi
Is there a compatibility list of plugins with the new Vray 3.0 ?
Forest Pack and RailCLone and they seem to work fine with the newly released beta.
Walls And Tiles - Seem to be just fine.
AutoGrass - Can someone comment on this plugin ?
Regards
NIR
About AutoGrass, I know that the developers do have a 3.0-compatible version, but I don’t know when it will be released - I will ask.
Thanks - Just got an email from Graham about it - saying he has a beta version.
BTW - Is there a general button in the Vray 3.0 UI that will enable the BASIC - ADVANCED - EXPERT in one press ?
I find it irritating having to go to each panel and swith to the EXPERT. Also - in the DEMO - sometimes parts of the UI even when a rollout is opened - there is nothing inside (even in Advanced mode) - maybe a UI issue ?
Regards
NIR
Yes: Chaos Docs
Also - in the DEMO - sometimes parts of the UI even when a rollout is opened - there is nothing inside (even in Advanced mode) - maybe a UI issue ?Hmm, do you have more specific reproduction steps?
Will do tomorrow or so
Going to sleep soon
Nir
Vlado,
Is there a maxscript access to this UI feature?
I would like to be able to have the UI extended as default. And one solution would be to get a maxscript in my startup script that extend the UI at startup or a bottom in my toolbars that extend all the UI at once?
Stan
The switchers are just regular renderer parameters; they are accessible from MaxScript.
I did manage to recreate it but then it was gone - the system rollout was invisible under the settings tab - but later it re-appeared.
Maybe it is something to do with 3ds max since I know that sometimes rollout may have visibilty issues.
NIR
