Vray 3.5 Beta - VrayLightMtl doesn't interactively update with IPR
It seems that VrayLightMtl doesn’t interactively update with IPR. You need to stop the IPR render and start it again for the changes to take effect.
Is the “direct illumination” option enabled?
Yes, it is. I also tried with it turned off but with the same result.
This works fine for me on a simple test scene. Can you give me some more detailed steps to reproduce it?
That’s strange. Here it doesn’t work properly. Please see the video attached. It’s tested on 3.50.01.
vray_3.5_IPR_vraylightmtl.zip (9.36 MB)
Can you send me the scene, could be something in the settings ? (peter.matanov@chaosgroup.com)
I think all Vray settings were at default but here’s the scene anyway. I hope it helps.
vray_3.5_IPR_VrayLightMtl_problem.zip (52.9 KB)
Indeed there is something buggy here, thanks for the report.
