Hi guys,
V-Ray just keep getting better and better!
The first thing I wanted to try is XGen to 3ds max via the VRayScene object. It works! Thank you so much for this feature ~~~
I made a hair mesh in Maya using XGen and exported a VRayScene via the Render Settings > Translator > export to .vrayscene file and pressing render. You can also export from the XGen > Preview/Output > Output Settings > Operation = vrayscene but I really don’t know what option is better or what the difference is. Maybe the export options are slightly different?
I then import the Hair into 3ds max using the brand new VRayScene Object and it renders perfectly
I wanted to ask how do I add a hair material from within 3ds Max to the VRayScene object? The material applied in Maya did carry over and render in 3ds max which is excellent but I would like to know how to apply materials from within max.
Is there a way to see what objects are in the VRayScene object and can you apply materials to those objects? I think it can be done in VRay for nuke if I remember correctly but can max have a VRayScene explorer to see the objects/materials in the VRayScene object?
I’m very happy with the new feature and I’m going to test if hair shaders done in XGen with expression will export to max via VRayScene Object.
For the moment it is not possible to assign existing 3ds Max materials to the .vrscene node. You can use the override box to do some things, including overriding of materials on objects in the .vrscene, however those materials are for the moment described in the vrscene format, rather than being taken from 3ds Max. This approach is good enough to override stuff with f.e. a simple grey diffuse material, but anything else becomes quite complicated (although possible in general).
We will be working on more user-friendly .vrscene overrides in the future. Other than applying 3ds Max materials to the contents of the scene, is there anything else you want to do with it?
Hi Vlado.
Just wanted to report something, the lock view-port doesn’t work in the latest Beta 2.
Suggestion 1
Also I wanted to ask what you think of the following suggestion.
When I mouse wheel up and down, it jumps by factors of 100. I would like to input or better control the VFB zoom more like Photoshop. The picture shows where you could place a Photoshop style zoom percentage in the VFB.
Is this stupid or a subtle improvement?
Suggestion 2
I wish that I could set and lock my camera but then Zoom into the camera view. Instead of zooming into the subject by zooming the actual camera, I wish that I could zoom into the image plane of my camera. I believe there is a script for maya that allows you to zoom into your own camera plane but not for 3ds max. Ill try to find it so you can see what I mean.
***Update***
Its called “zoomerator-for-maya”. Yes, I wish that was a thing max/vray could do. What do you think?
Wow thank you! I didn’t know that. Yes, can V-Ray support it?. But is he still moving the camera? ~ I want the camera view locked so Im not moving the camera but able to zoom into the picture plane of my camera just like in zoomerator-for-maya. I wish there were a video demo of zoomerator sommewhere to show you.
I was trying to think of those little features that are super convenient. I felt the need to set up my camera shot and lock it but also be able to zoom into the picture plane.
Also Recon442 what do you think of the other idea? = I don’t like the VFB zoom as it jumps by factors of 100% So I think a simple solution would be a photoshop like zoom factor input and or slider for smoother zooming into the pixels of a render.
Could it be that vray takes too much performance? Especially when rendering big images with the progressive sampler. I’m currently rendering a 8k×2k stereo spherical image with low thread priority. And my computer freezes most of the time. I waited 20 minutes for being able to cancel… i’ve a 5960x with 32gb ram, 10 gigs are in use while rendering.
