Vray 3.50.03 doesn't save properly render elements to .vrimg file.
When saving to .vrimg I have wrong render elements…
for example:
‘atmosphere’ is the same as ‘effectsResult’
‘refractionFilter’ is blank
‘reflectionFilter’ is refractionFilter
‘diffuseFilter’ is reflectionFilter
‘worldNormals’ is diffuseFilter
‘worldPositions’ is worldNormals
defocusAmount is blank
and couple more.
when saving to .exr it’s ok
no problems here.
edit:
but without denoiser. this might be an issue.
same problem here
Hello!
I suppose you use the VRayDenoiser with mode Only generate render elements? If this is the case, we actually have a fix for this already and it should be included in the next release.
If not, I’ll need more details on your setup to reproduce it here.
Thank you!
Margarita
Yes, that’s exactly right ! :slight_smile: Good to hear that there is a fix for it.
