I am using material override with Vray 5 and just discovered that the material override does not seem work correctly on materials without a diffuse map (ie materials that’s just colors from sketchup).
The material seems to be overrided, but without the correct size. The material override works well on materials with diffuse maps.
Are there any way to fix this? So that the material override appears with the same texture size on all surfaces.
Best regards
