Vray-5 | Problems applying materials to vray fur objects
Hi everybody.
If i set some default material library material to fur object, and i start a render this is the result. If i set a default material there are no problems. If i start an interactive render there are no problems. There is this problem only in the production/progressive mode.
I had this problem since the new version 5. I’m using rhinoceros 6, with a 1070 ti.
Hello @BossFx
This Issue has been logged in our system - ref num 2986
As a workaround please use Full-size textures or Resize textures options under the GPU Memory Management menu.
thankyou very much, i will try.
meanwhile i’m using a generic material with the same texture (i have opened the .tx texture from chaosgroup library, converted into a jpg)
A solution for this problem has been devised. It will be included in the next V-Ray 5 for Rhino update.
Kind regards,
Peter
