Hello
I was wondering if vray hybrid rendering is still an option rtx + cpu maybe? Can’t find that option, I thought once it was there back in V5.
Cheers
Rafal
Hello
Cheers
Rafal
Are there any benchmarks if Hybrid is really faster than RTX.
I would do some tests but i have no workstation at the moment.
Hello @oglu ,
You can compare the score of V-Ray CUDA agains V-Ray CUDA hybrid. However, as the score points of V-Ray, V-Ray GPU CUDA and V-Ray GPU RTX are different for the engines, you won’t be able to compare the scores for the different engines.
You can check the V-Ray Benchmark results here. You can also find more information about V-Ray Benchmark here. I hope this is of help.
Hey!
If you have a good CPU, Cuda mode + CPU should be faster in most cases
Optix will shine in scene with hair, fur or grass, where you have large surface of geometry intersecting with lighting
Best,
Muhammed
I managed todo a short test. A pile of coins with a gold shader.
RTX 2min 30sec
CUDA CPU+GPU 2min 45sec
CUDA GPU 3min 60sec
CPU with a much lower noise threshold to get the same feeling of noise 5min 49sec
AMD Ryzen 5950
Geforce 3060
Before I final render a job, I always test CUDA-Hybrid and RTX-GPU rendering. Sometimes CUDA-Hybrid is faster and sometimes RTX-GPU is faster.
Bevor ich einen Job Final rendere, teste ich immer CUDA-Hybrid- und RTX-GPU Rendering. Manchmal ist CUDA-Hybrid schneller und manchmal ist RTX-GPU schneller.
