Vray and Yeti Batch render issues
Hi, I have problems with batch rendering on the renderfarm with Yeti and Vray. Some computers work and some do not. All computers have the same linux system: Ubuntu 14 Trusty. The computers that do not work are fast machines with more RAM than the ones that do work. Any Ideas?
Output:
[2014/Aug/22|11:33:32] V-Ray: pgYetiVRay: reading /mnt/he-film/test_project/Maya/yeti/Yeti_cache/test.0026.fur
[2014/Aug/22|11:33:32] V-Ray: Compiling geometry…
maya.bin: malloc.c:2372: sysmalloc: Assertion `(old_top == (((mbinptr) (((char *) &((av)->bins[((1) - 1) * 2])) - __builtin_offsetof (struct malloc_chunk, fd)))) && old_size == 0) || ((unsigned long) (old_size) >= (unsigned long)((((__builtin_offsetof (struct malloc_chunk, fd_nextsize))+((2 *(sizeof(size_t))) - 1)) & ~((2 *(sizeof(size_t))) - 1))) && ((old_top)->size & 0x1) && ((unsigned long) old_end & pagemask) == 0)’ failed.
I am using:
V-Ray for Maya 2014 version 2.45.01, revision 24870 and Yeti v1.3.12
This seems more like a Yeti issue rather than V-Ray. How many cores do you have in these machines? Perhaps Yeti needs more memory proportionally to the number of threads…
Oke that could be the reason, the computers that do work have 8 cores and the computers that are not working have 24 cores
Do I need to increase dynamic memory limit for this?
No, I don’t think it will help.
Yeti has an option to specify how many threads to use when generating the hair - perhaps try to set this to 8 and see if it helps?
Ok thanks, do you know where I can find that option in Yeti?
The documentation of Yeti says that the Yeti Maya node has an attribute “Render Threads” in its “Render” rollout:> Render Threads - The number of threads to use when evaluating the graph at render time, 0 = all threads.
Lol, I see it in the docs, but I can’t find it in the interface. I 've posted this issue at the yeti forum but I am still waiting for replies…
Ok. Well, if you don’t get a reply, there is a way to hack it through the V-Ray post-translate Python callback, so let me know how it goes.
it would be cool to get the post-translate hack. Colin responded on the Yeti forum and asked if you could contact him about this issue :slight_smile:
