Vray Blend Material Problem
I´m having a problem getting the Vray Blendmaterial to work properly.
I´m using a Vray FastSSS2 Material as the base and a normal Vraymaterial as the coat.
I then applied a B/W-gradient ramp to the mask slot to blend between them.
As far as Ißve understood, I should not see any of the coat material on parts theat are black on my gradient ramp.
But somewhow i always get a certain amount of the coat material mixed in…
Am I doing something wrong here? Because the standard Max Blendmaterial works just fine.
