It would be nice to be able to disable lense breathing for vray camera
̶W̶e̶ ̶a̶l̶r̶e̶a̶d̶y̶ ̶h̶a̶v̶e̶ ̶a̶n̶ ̶i̶m̶p̶r̶o̶v̶e̶m̶e̶n̶t̶ ̶r̶e̶q̶u̶e̶s̶t̶ ̶l̶o̶g̶g̶e̶d̶ ̶f̶o̶r̶ ̶t̶h̶i̶s̶ ̶(̶V̶M̶A̶X̶-̶1̶4̶3̶8̶2̶)̶.̶ ̶A̶d̶d̶i̶n̶g̶ ̶a̶ ̶b̶u̶m̶p̶ ̶o̶n̶ ̶y̶o̶u̶r̶ ̶b̶e̶h̶a̶l̶f̶.̶
EDIT: Check posts below.
Great
Actually, what do you mean by Lens Breathing? The zooming when changing the FOV/Focus? Because I might have linked a different log (focal distance/exposure relationship).
When you change focus distance the camera FOV changes because lens breething is always on right now. You can see it in Max’s build-in physical camera where lense breething is as an option.
Okay. In that case, please add this idea to the Portal, too.
You can easily disable breathing by switching to FOV mode instead of focal length mode.
First thing I do on a camera, as the breathing is almost never desired in camera (we add in post if needed). It makes focal length changes too unpredictable when your image scales as well, mainly when close up/macro of course.
I would prefer a checkbox to enable or disable it even in focal length mode.
Yes I know this but its just a workaround, it would be much nicer to have possibility to disable it in focal length mode.
